This category is for how-tos and tutorials for the TD RF modules and related projects.
batchris
Virtualbox with SDK and source to build installed
by batchris Tue Mar 14, 2017 9:57 am
Bonjour,
have you a image virtualbox (or other) with all sdk and tools for build and dev. for TDxxxx ?
Thank's
Chris
Re: Virtualbox with SDK and source to build installed
by mstempin Wed Apr 12, 2017 3:35 pm
No, the SDK is only supported under Windows, and packing a Windows into a VM is not legal, unfortunately.
But apart from the Segger and FTDI drivers which obviously should be installed to work correctly, everything else is pretty much portable: the main tools are installed by unpacking the provided ZIP file at the root of your C: drive (mandatory because of some Eclipse paths), requiring no installation (even the correct JRE is included).
Return to Tutorials
