This category is for how-tos and tutorials for the TD RF modules and related projects.
two-way communication?
by kjkoster Mon Aug 15, 2016 11:34 am
Dear All,
On (slide #8) Nicolas Lesconnec mentions that two-way communication is possible. I cannot find anything related to sending data from the server to the device in the documentation. Can someone please point me to the relevant documentation for getting a message from the server to the device? Is that sent as response to a device message?
Kees Jan
Re: two-way communication?
by mstempin Wed Aug 24, 2016 9:27 am
Yes, this is the so-called Sigfox "downlink" feature. As the device is not listening all the time for power consumption reasons, it only listen to messages from the network after sending a message with an acknowledgment request. This is detailed under the etry for the "AT$SF" command in the module's user's manual. When using the C API, you can refer to the "examples\rf\sigfox_downlink\src\sigfox_downlink.c" example within the SDK sources.
Return to Tutorials
