This category is for how-tos and tutorials for the TD RF modules and related projects.
Issues logging into the backend
by kjkoster Sun Aug 14, 2016 6:45 pm
I have a TD1204 EVB. I tried sending a message and that worked (in the sense that the unit responded with OK). Then I tried to log into the backend at and found that I could not. I entered the TDID below as the module ID, but I am not sure where to find the module key. Can someone shed some light on that, please?
Telecom Design TD1204
Hardware Version: 01
Software Version: SOFT1450
S/N: 000151C2
TDID: 539000429778
E1 V1 Q0 X1 S200:0 S300:24 S301:2 S302:14 S303:1 S304:20 S305:25 S350:0 S351:32768 S352:1 S353:10 S400:000000 S401:FFFFFF S402:0 S403:869412500 S404:14 S405:32 S406:1
Re: Issues logging into the backend
by mstempin Wed Aug 24, 2016 9:29 am
The required ID an key used to access the device dashboard are located on a sticker on the bottom side of the TD1204 EVB board.
Return to Tutorials
